[Sponsors] | |||||
Arun Issac
Rep Power: 10 ![]() |
Hi community,
I have a basic question. How dependent is temperature on y plus for external aerothermal flows. Could you please share your experience with SST k-w model. |
Hamid Zoka
Rep Power: 20 ![]() |
If it is a pressure driven problem, Yplus value can change if viscosity and density change significantly by temperature. In case of temperature driven problems like buoyancy, however, temperature variations can have a more substantial impact on it through changing the physics of the flow. Best |
#3 | |
Maybe you want to know how sensitive to y+ is a computed surface temperature distribution when using the SST k-w model on a mesh with a given y+ for that surface? This kind of depends from the solver you are using and, indeed, the current y+ value and kind of flow. For example, if your current y+ value is 2, there is possibly already little sensitivity going to 1 or 3. If your current value is 15, depending from how the wall function is implemented and which wall function formulation is used, you might experience larger sensitivities. This is especially so if there are large streamwise pressure gradients that the wall function doesn't take into account. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 17:05 |
| [swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
| [Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 04:04 |
| [foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
| DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
