checkMesh - Foam Fatal IO Error - newbi
5 Attachment(s)
Hi, sorry for bother you. I am newbi
I cannot run checkMesh command. Yesterday I was running it on system folder and when researching I learned that commands must be done on top folder, I tried again but got Code:
--> FOAM FATAL IO ERROR: (openfoam-2206) |
You should run (almost) all commands from the top level dir, in this example that would be SmokingPipefoam. Although you can run some commands like checkMesh from within the constants folder.
Make sure your controlDict is in SmokingPipefoam/system and is not buried in more subdirectories. Make sure it is a valid controlDict. In this example, it looks like your control dict or another dict is missing the OpenFOAM header if it can even find your controlDict at all. The header is absolutely necessary because foam needs to know that it is reading ascii text and not other coded formats. Code:
/*--------------------------------*- C++ -*----------------------------------*\ |
There is controlDict
https://1drv.ms/u/s!AgN4cFrYS98LkxCo...PY4H8?e=BpOwmn |
The error is saying this line is missing from one of your dicts
format ascii; |
