Adarsh
Rep Power: 5 ![]() |
How do you calculate Hydraulic diameter of a catalytic convertor? Does middle section also need to be taken in account?
Rep Power: 2 ![]() |
The hydraulic diameter is used to calculate a representative length-scale for non-circular ducts. So you need to apply a bit of engineering judgement based on the phenomena you seek to model or study.
Do you want to understand the hydrodynamics of the gas in the inlet pipe? Then you can use the pipe diameter. The sudden expansion into the main section is a commonly-studied flow situation. Surely you have a porous medium representing the catalytic surface. At the microscale, the important representative dimension is the channel hydraulic diameter which you can calculate easily. But this is an entirely different problem then the bulk flow in the duct. |
Display Modes | |
How to calculate Turbulent Intensity and Hydraulic Diameter for my problem? | Roh | FLUENT | 1 | June 17, 2018 03:12 |
diameter equivalent and hydraulic diameter | medaouarwalid | Main CFD Forum | 6 | June 22, 2017 02:33 |
[GAMBIT] hydraulic diameter? | Zweeper | ANSYS Meshing & Geometry | 6 | January 4, 2010 00:44 |
hydraulic diameter in 2d | ahsan | FLUENT | 2 | August 28, 2009 15:22 |
Importance of Hydraulic Diameter Value for Compressible Flow | RyGuy | FLUENT | 0 | August 6, 2009 10:58 |
