UDF velocity inlet
1 Attachment(s)
Hello everyone,
i have little problem, i have created an UDF File, for velocity inlet, in a tube but when i plot it with report definition, i dont get a sinusoid, i want to know what is the problem, i have define correctly UDF file in user define fonction, but the plot and values obtained aren't correct. Thank you for your help |
The profile UDF looks fine. if there is any compilation issue, please check for errors. if there is no compilation issue Please see below: 1. since your velocity profile is dependent on time, if you plot at the beginning it will give Uinlet=30. but as the time gets updated, you will see a nice sine profile curve at your velocity inlet. |
