wave from body passing through slit
Old   August 25, 2000, 10:08
Default wave from body passing through slit
Lasse Johansson
Hi
I am trying to examine the wave emitted when a moving body, which displacing the fluid around it, passes through a slit. The body could be a ship moving in shallow water. The Mach number is small, i.e. the ship is slower than a (long) wave, there is no dispersion and the problem is 2D. Does anyone know of analytical solutions to this problem that can be used to validate a numerical solution?
Wave Rotor simulation popezmark OpenFOAM 8 February 4, 2014 18:00
6DOF with floating body bounce back. paka FLUENT 4 June 6, 2013 11:32
active wave absorb(about wave tank) zhaochuangang ANSYS 0 September 22, 2010 02:29
Scaling up a wave energy converter - free surface flow mark_l CFX 3 February 17, 2010 16:57
Pressure wave pattern over body in steadystate? Chebeba CFX 1 March 16, 2008 02:00
