Pipe Roughness Coefficients and RMS
Old   September 19, 2000, 20:12
Default Pipe Roughness Coefficients and RMS
Brian Everett
I'm trying to figure out the relationship between the absolute roughness of the interior surface of steel pipe and the RMS (root mean square) surface finish number used by pipe manufacturers. I believe the RMS number is given in microns and can therefore be related back to absolute roughness which is given in either ft. or inches. Please let me know if there is a table that correlates the two...thanks.
Old   September 20, 2000, 14:46
Default Re: Pipe Roughness Coefficients and RMS
John C. Chien
(1). If you type "pipe roughness" into a web search site, such as yahoo, you will get many websites related to the pipe roughness. (2). One of the place to begin with is http://www.efunda.com/formulae/fluids/roughness.cfm
Old   September 20, 2000, 15:41
Brian Everett
Thanks, I had been to the efunda web site yesterday but had overlooked that particular table. So I'm now assuming that an RMS surface finish is usually given in a value of microns??? If so, that can easily be equated to an absolute roughness coefficient.
RMS of lift coefficient A. David Main CFD Forum 3 May 12, 2016 06:03
rms of pressure coefficients kbutler FLUENT 0 August 27, 2007 18:20
