Shedding Frequency
Old   August 28, 2000, 15:53
Default Shedding Frequency
Oliver
Hi All
Suppose a sensor is mounted on cylinder, which is shedding vortices at some specific rate. Vortices are shed say from the upper and lower surface of the cylinder. Now suppose a line is drawn downstream in the wake. Is the rate of vortices that pass through this line the shedding frequency. Or is the oscillation (i.e. the growth of the vortex on one side only) seen by the sensor the sheeding frequency.
Is it pressure waves travelling upstream from the shed vortices that the sensor sees???
Or
Is it the growth of the vortex on one side of the cylinder???
Regards
Oliver
Old   August 28, 2000, 17:28
Default Re: Shedding Frequency
John C. Chien
(1). In the case of the Von Karman vortex street, at any time, you have the spacing between two neighboring vortices. (2). And if you fix the probe at on location and plot the signal, you should be able to see the oscillating profile, which can be used to define the amplitude, and the frequency.
Old   September 5, 2000, 07:40
Oliver
Thanks again John for the valuable advice.
regards oliver
vortex shedding frequency naveen OpenFOAM 23 May 17, 2016 08:12
frequency of vortex shedding HaKu Main CFD Forum 3 March 18, 2011 00:00
time step and vortex shedding frequency kevin Main CFD Forum 16 November 19, 2009 06:00
Vortex shedding frequency stays unaltered Nelson Main CFD Forum 3 March 5, 2009 10:04
flow over a cylinder: shedding frequency Ruslan FLUENT 1 July 19, 2005 09:49
