flow past 2-d cylinder
Old   August 28, 2000, 07:38
Default flow past 2-d cylinder
K.S.Ravichandran
Hi
does anyone know about an accurate, "proven" N-S solver for impulsively started cylinder?
KSR
Old   August 28, 2000, 14:03
Default Re: flow past 2-d cylinder
Adrin Gharakhani
For the incompressible flow version check the following (excellent) thesis:
Shankar Subramanian, "A New Mesh-Free Vortex Method," PhD Thesis, The Florida State University, 1996.
The method has been used for up to Re=40,000 with excellent success (DNS - no turbulence models). The standard benchmark at Re=9500 compared very well with a spectral element solution using a much smaller number of computational elements.
Adrin Gharakhani
Old   August 28, 2000, 23:58
K.S.Ravichandran
Dr.Adrin
Thanx very much
KSR
Old   August 31, 2000, 11:08
Selvarajan
Supposing one gets symmetric wake solution, say for R=9500, even when for a long time integration, is it a desirable feature in a code? Selvarajan
Old   August 31, 2000, 18:41
Adrin Gharakhani
Yes, IF one can get such a solution for LONG times! A symmetric wake will be a valid solution and moreover it will be an indication of an (extremely) clean code/methodology. I doubt this will be possible and sooner than later numerical perturbations will creep in, giving rise to the familiar asymmetry.
Incidentally, the above has been verified experimentally as well. That is, one can extend the life of symmetry in "real" life if one has a clean setup.
If one has a clean code/algorithm, then it is a simple matter to introduce perturbations in the field and watch the instabilities grow, but the reverse is not true.
Adrin Gharakhani
Old   September 1, 2000, 10:56
S.Selvarajan
Thank you very much.
Supposing one introduces disturbances and tries to study the vortex shedding features, why does it take unrealistic time for the first vortex to shed? Or, often you need a large disturbance to disturb the flow. Could you please comment on these?
Regards selvarajan
Old   September 1, 2000, 14:48
Adrin Gharakhani
I don't know what you mean by "unrealistic time". In engineering/science one generall has the luxury of quantifying items; why not take advantage of it!
And, unrealistic compared to what? If compared to experiments, how do you know what the perturbation amplitudeS are in this case?
It makes sense to me that small-amplitude perturbations will take longer to grow than relatively larger ones. But, the question for me is whether your numerical methodology can capture inviscid instabilities accurately or the numerical diffusion is so high that it damps out "small" perturbations.
I'm rusty on stability analysis (database-wise), but I'm sure there are theoretical studies for the cylinder flow case (this should give you a theoretical guideline)
Adrin Gharakhani
Old   September 3, 2000, 06:26
Selvarajan
Hi Dr. Adrin,
Thank you very much. I will look into theoretical studies on stability of flow past a cylinder.
Selvarajan.
2D modelling of flow past a rotating cylinder pds24 Main CFD Forum 1 August 21, 2015 10:50
CFD help: flow past cylinder harsha00711 Main CFD Forum 1 December 24, 2010 21:19
Flow past cylinder harry FLUENT 0 May 29, 2006 06:18
meshing for flow past a cylinder karthik FLUENT 1 July 15, 2005 06:17
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
