WM_PROJECT_DIR: parameter not set or null. How to setup an environment for OpenFOAM?
I installed on Ubuntu Jammy Jellyfish (WSL2):
Distributor ID: Ubuntu Description: Ubuntu 22.04.4 LTS Release: 22.04 Codename: jammy from these instructions. After adding a repository: sudo apt-get install openfoam2312-default OK... So I have some examples: /usr/lib/openfoam/openfoam2312/tutorials/incompressible/pimpleFoam/LES/vortexShed ``` /usr/lib/openfoam/openfoam2312/tutorials/incompressible/pimpleFoam/LES/vortexShed$ sudo ./Allrun ./Allrun: 3: WM_PROJECT_DIR: parameter not set or null ``` I also ran "source bashrc" from the openfoam/etc folder. How can I get Allrun to run? |
Your installer isn't working. The environmental variable should be set during the install but is generally a big no-no without root privileges (that's the best way to get a virus!).
source the etc/bashrc again and run ./Allwmake to compile OF again. If still the same error then echo $WM_PROJECT_DIR and verify that it is set. If still unset then check the bashrc to make sure it is set and then set it and compile. In general I recommend to never read a guide that has sudo in it (it's generally written by dummies for dummies). |
Good
It is recommended to set and double-check the environmental variable during the installation process.
----------------------------------- run 3 |
