The Solver Failed with a non zero exit code of 2
I am trying to simulate a NACA0012 airfoil 2D. I have 8 logical processors. I tried with 4 hoping that would help as has year ago but not now. I really need help. I have copied and pasted what CFX solver produced :
This run of the CFX 2023 R1 Solver started at 21:17:22 on 06 Apr 2024 by user o2-azoui on STU-CZC8208KCC (intel_xeon64.sse2_winnt) using the command: "C:\Program Files\ANSYS Inc\v231\CFX\bin\perllib\cfx5solve.pl" -batch -ccl runInput.ccl -fullname "1 NACA 0012 Square Domain_002" 2023 R1 Point Releases and Patches installed: ANSYS, Inc. License Manager 2023 R1 Discovery 2023 R1 SpaceClaim 2023 R1 Ansys Sherlock 2023 R1 Autodyn 2023 R1 LS-DYNA 2023 R1 CFD-Post only 2023 R1 CFX (includes CFD-Post) 2023 R1 Chemkin 2023 R1 EnSight 2023 R1 FENSAP-ICE 2023 R1 Fluent (includes CFD-Post) 2023 R1 Polyflow (includes CFD-Post) 2023 R1 Forte (includes EnSight) 2023 R1 TurboGrid 2023 R1 ICEM CFD 2023 R1 Motion 2023 R1 Aqwa 2023 R1 Speos 2023 R1 Speos HPC 2023 R1 Speos for NX 2023 R1 optiSLang 2023 R1 Additive 2023 R1 Customization Files for User Programmable Features 2023 R1 Mechanical Products 2023 R1 Material Calibration App 2023 R1 Icepak (includes CFD-Post) 2023 R1 Remote Solve Manager Standalone Services 2023 R1 Ansys Sound - SAS 2023 R1 Viewer 2023 R1 ACIS Geometry Interface 2023 R1 AutoCAD Geometry Interface 2023 R1 Catia, Version 4 Geometry Interface 2023 R1 Catia, Version 5 Geometry Interface 2023 R1 Catia, Version 6 Geometry Interface 2023 R1 Creo Elements/Direct Modeling Geometry Interface 2023 R1 Creo Parametric Geometry Interface 2023 R1 Inventor Geometry Interface 2023 R1 JTOpen Geometry Interface 2023 R1 NX Geometry Interface 2023 R1 Parasolid Geometry Interface 2023 R1 Solid Edge Geometry Interface 2023 R1 SOLIDWORKS Geometry Interface 2023 R1 Setting up CFX Solver run ... +--------------------------------------------------------------------+ | | | CFX Command Language for Run | | | +--------------------------------------------------------------------+ LIBRARY: MATERIAL: Air Ideal Gas Material Description = Air Ideal Gas (constant Cp) Material Group = Air Data, Calorically Perfect Ideal Gases Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Molar Mass = 28.96 [kg kmol^-1] Option = Ideal Gas END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 2.61E-2 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 0.01 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END END END END FLOW: Flow Analysis 1 SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END ANALYSIS TYPE: Option = Steady State EXTERNAL SOLVER COUPLING: Option = None END END DOMAIN: Default Domain Coord Frame = Coord 0 Domain Type = Fluid Location = B32 BOUNDARY: Inlet Boundary Type = INLET Location = Inlet BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END HEAT TRANSFER: Option = Static Temperature Static Temperature = 288 [K] END MASS AND MOMENTUM: Normal Speed = 51 [m s^-1] Option = Normal Speed END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END END BOUNDARY: Opening Boundary Type = OPENING Location = Bottom,Top BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END HEAT TRANSFER: Opening Temperature = 288 [K] Option = Opening Temperature END MASS AND MOMENTUM: Option = Entrainment Relative Pressure = 0 [Pa] END TURBULENCE: Option = Zero Gradient END END END BOUNDARY: Outlet Boundary Type = OUTLET Location = Outlet BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Average Static Pressure Pressure Profile Blend = 0.05 Relative Pressure = 0 [Pa] END PRESSURE AVERAGING: Option = Average Over Whole Outlet END END END BOUNDARY: Symmetry Boundary Type = SYMMETRY Location = Symmetry 2,Symmetry 1 END BOUNDARY: Wall Boundary Type = WALL Location = Wall BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END DOMAIN MODELS: BUOYANCY MODEL: Option = Non Buoyant END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 101325 [Pa] END END FLUID DEFINITION: Fluid 1 Material = Air Ideal Gas Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Include Viscous Work Term = True Option = Total Energy END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = SST END TURBULENT WALL FUNCTIONS: High Speed Model = Off Option = Automatic END END END OUTPUT CONTROL: RESULTS: File Compression Level = Default Option = Standard END END SOLVER CONTROL: Turbulence Numerics = First Order ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Length Scale Option = Conservative Maximum Number of Iterations = 100 Minimum Number of Iterations = 1 Timescale Control = Auto Timescale Timescale Factor = 1.0 END CONVERGENCE CRITERIA: Residual Target = 0.000001 Residual Type = RMS END DYNAMIC MODEL CONTROL: Global Dynamic Model Control = On END INTERRUPT CONTROL: Option = Any Interrupt CONVERGENCE CONDITIONS: Option = Default Conditions END END END END COMMAND FILE: Version = 23.1 Results Version = 23.1 END SIMULATION CONTROL: EXECUTION CONTROL: EXECUTABLE SELECTION: Double Precision = Yes Large Problem = No END INTERPOLATOR STEP CONTROL: Runtime Priority = Standard MEMORY CONTROL: Memory Allocation Factor = 1.0 Option = Model Based END END PARALLEL HOST LIBRARY: HOST DEFINITION: stuczc8208kcc Remote Host Name = STU-CZC8208KCC Host Architecture String = winnt-amd64 Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX END END PARTITIONER STEP CONTROL: Multidomain Option = Automatic Runtime Priority = Standard MEMORY CONTROL: Memory Allocation Factor = 1.0 Option = Model Based END PARTITION SMOOTHING: Maximum Partition Smoothing Sweeps = 100 Option = Smooth END PARTITIONING TYPE: MeTiS Type = k-way Option = MeTiS Partition Size Rule = Automatic Partition Weight Factors = 0.25000, 0.25000, 0.25000, 0.25000 END END RUN DEFINITION: Run Mode = Full Solver Input File = 1 NACA 0012 Square Domain.def Solver Results File = F:/ CFD DISS/Smooth NACA 0012 Validation \ Model Process_pending/dp0_CFX_3_Solution_3/1 NACA 0012 Square \ Domain_002.res END SOLVER STEP CONTROL: Runtime Priority = Standard MEMORY CONTROL: Memory Allocation Factor = 1.0 Option = Model Based END PARALLEL ENVIRONMENT: Number of Processes = 4 Start Method = Intel MPI Local Parallel Parallel Host List = stuczc8208kcc*4 END END END END +--------------------------------------------------------------------+ | | | Partitioning | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | | | ANSYS(R) CFX(R) Partitioner | | | | 2023 R1 | | Build 23.1 2022-11-25T14:31:12.124816 | | Fri Nov 25 16:56:29 GMTST 2022 | | | | Executable Attributes | | | | double-64bit-int32-archfort-optimised-std-lcomp | | | | (C) 1996-2023 ANSYS, Inc. | | | | All rights reserved. Unauthorized use, distribution or duplication | | is prohibited. This product is subject to U.S. laws governing | | export and re-export. For full Legal Notice, see documentation. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Job Information at Start of Run | +--------------------------------------------------------------------+ Run mode: partitioning run Host computer: STU-CZC8208KCC (PID:656) Job started: Sat Apr 6 21:17:32 2024 +--------------------------------------------------------------------+ | License Information | +--------------------------------------------------------------------+ License Cap: ANSYS CFD Solver License ID: STU-CZC8208KCC_campus_ads_uwe_ac_uk-o2-azoui-15440-000810 License Cap: ANSYS HPC Parallel License ID: STU-CZC8208KCC_campus_ads_uwe_ac_uk-o2-azoui-15440-000823 INFO: You are using an academic license. +--------------------------------------------------------------------+ | Initial Memory Allocation (Actual usage may vary) | +--------------------------------------------------------------------+ | Real | Integer | Character | Logical | Double ----------+------------+------------+-----------+----------+---------- Mwords | 8.60 | 167.72 | 8.85 | 0.12 | 0.00 Mbytes | 65.63 | 639.80 | 8.44 | 0.46 | 0.00 ----------+------------+------------+-----------+----------+---------- +--------------------------------------------------------------------+ | Host Memory Information (Mbytes): Partitioner | +--------------------------------------------------------------------+ | Host | System | Allocated | % | +-------------------------+----------------+----------------+--------+ | STU-CZC8208KCC | 32647.21 | 714.33 | 2.19 | +-------------------------+----------------+----------------+--------+ +--------------------------------------------------------------------+ | The MeTiS partitioning method allocates additional memory. | | Total memory usage will therefore exceed the values shown above. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Topology Simplification | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ****** Warning ****** | | | | Topology simplification is activated with the following | | restrictions: | | | | - Mesh regions referenced only within User Fortran and NOT | | in the command file will cause the solver to stop. | | - The solver will stop during any "Edit Run in Progress" step | | if new 2D regions are referenced. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Mesh Statistics | +--------------------------------------------------------------------+ Domain Name : Default Domain Total Number of Nodes = 1701406 Total Number of Elements = 9611401 Total Number of Tetrahedrons = 9536911 Total Number of Prisms = 74490 Total Number of Faces = 265544 +--------------------------------------------------------------------+ | Vertex Based Partitioning | +--------------------------------------------------------------------+ Partitioning of domain: Default Domain +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | SYMASS_ZONE_EL : The solver ran out of temporary space while buil- | | ding a linked list for a domain. Try setting the expert paramete- | | r "topology estimate factor" to a value greater than 1.0. Values | | higher than 1.2 should not be necessary. | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine SYMASS_ERROR | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX partitioner exited with return code 1. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | F:/CFD DISS/Smooth NACA 0012 Validation Model | | Process_pending/dp0_CFX_3_Solution_3/1 NACA 0012 Square | | Domain_002: | | | | trace | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | For CFX runs launched from Workbench, the final locations of | | directories and files generated may differ from those shown. | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. |
