Does recirculation zone present in laminar flow?
Old   May 11, 2024, 06:43
Default Does recirculation zone present in laminar flow?
Görkem
swindlers is on a distinguished road
I am trying to model a 2D rayleigh step bearing.The wall with a step is stationary and straight one is moving. Pressures are identical at the inlet and outlet so flow is friction driven and its direction is from wide channel to the narrow channel.
Flow Geometry:
What I am asking is, the flow is definitely laminar in both wide and narrow channels (Re=100-500). However, because of the step there will be recirculation zone and flow seperation zone.
I was planning to use laminar viscous model in CFD but I am in doubt. Can recirculation zone also present in laminar flow? Can laminar viscous model capture the physics in the near-wall region of recirculation zones?
Thanks in advance
swindlers is offline   Reply With Quote
Old   May 11, 2024, 13:53
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
There are a lot of case of laminar flows with recirculation. At low Re number you can simulate your flow problem without turbulence models. However, the real physics could be 3d.
In any case, you need a grid that resolved the BLz
FMDenaro is online now   Reply With Quote
Averaging over iterations for steady-state simulation CFD student Fluent UDF and Scheme Programming 8 September 22, 2022 03:39
laminar flow in one zone and kEpsilon model in the other zone super1 OpenFOAM Running, Solving & CFD 0 December 28, 2016 08:29
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
Difference between recirculation zone and turbulent flow region ashtonJ Main CFD Forum 0 September 16, 2011 03:46
