Post processing of discrete phase model in fluent
Old   October 15, 2024, 14:09
Question Post processing of discrete phase model in fluent
Linas is on a distinguished road
I’m using the pressure swirl atomizer injection to simulate atomization of water. This is an unsteady state simulation. I have specified the injection pressure and flowrate for water, while air is stagnant. During the simulation, I sample droplets exiting the outlet and the droplets present in the air volume. The Sauter mean, diameter for both samples are similar. I also generate a summary of the injection after stopping the simulation. This summary generates particle size distribution data for the current particles in the simulation. The saucer mean diameter obtained at this sample is smaller than what I get from the sampling at the outlet and the air volume.
Is this difference to be expected from the physics of the flow due to depressurization as the fluid is sprayed out of the nozzle? Or is there some error in my simulation?
Linas is offline   Reply With Quote
atomization, discrete phase model
DPM or dense discrete phase model? curious scientist FLUENT 1 December 16, 2022 07:03
Fluent Limitations tymcme FLUENT 6 August 1, 2022 09:50
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 09:38
A Query on Dense Discrete Phase Model - Transition Factor shashwatb Fluent Multiphase 0 June 16, 2015 10:55
