Negative initial flow rate in Ansys CFX 2-way FSI
Old   December 26, 2024, 19:31
Default Negative initial flow rate in Ansys CFX 2-way FSI
BWLi is on a distinguished road
Hi all,
First, Merry Christmas and Happy New Year!
I am recently trying to run a 2-way FSI with Ansys CFX and Transient Structural modules. It is a physiological case hence I set my initial pressure condition in CFX to 10666 Pa (80 mmHg equivalent). I verified the settings by running standalone CFX and Structural modules, respectively, and there is no problem.
However, during my coupling, my initial flow rate output from CFX is negative. I had never seen this situation before from CFD, and ideally the first step should not produce a large displacement transfer back to the fluid domain.
I am therefore wondering, how do CFX and Transient Structural initialise the solution at the first step.
A few things I have tried:
- 1-way FSI from CFX to Transient Structural only: no problem
- 2-way FSI but change the material property to ** structural steel **: no problem, but not physiologically true.
- lower my initial pressure: my initial flow rate is less negative, but does not really make a diff.
BWLi is offline   Reply With Quote
ansys, cfx, fsi 2-way, initialization, system coupling
Suppress twoPhaseEulerFoam energy AlmostSurelyRob OpenFOAM Running, Solving & CFD 33 September 25, 2018 18:45
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
