Nano Particles as Single Phase Flow vs Water
Old   January 3, 2025, 23:54
Default Nano Particles as Single Phase Flow vs Water
mehdihaider2012 is on a distinguished road
I am running a CFD simulation to evaluate the heat transfer characteristics of heat exchanger, using water and water with nano particles.
The CFD simulation was first performed using the water as a base fluid only. I kept the inlet velocity as 2 m/s for that simulation and the Re was 515.
Now I want to run the simulation again with water as the base fluid along with nano particles. So what should I keep the inlet velocity? When I used 2m/s and re-evaluated the Re, it came out to be 600+ Re in this case (as density and kinematic viscosity changed). Should I reduce the velocity for this case to make the Re around 515 for comparison with the previous case? as in research papers I find Nusselt Number vs Reynold Number graphs.
mehdihaider2012 is offline   Reply With Quote
cfd, nano particles, single phase flow
Turbulence Eddy Freqency bounds error when using single phase flow vs two phase flow Eman Eal CFX 1 October 30, 2024 17:26
What are the best settings for a channel flow simulation? Ashkan Kashani CFX 3 October 13, 2022 22:36
unable to run dynamic mesh(6dof) and wave UDF shedo Fluent UDF and Scheme Programming 0 July 1, 2022 18:22
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 15:27
Algorithms for single phase flow equation of oil reservoir fluid aadi.engr Main CFD Forum 0 April 2, 2014 17:01
