Roll And Yaw Stability of Airplane
Old   January 14, 2025, 11:55
Default Roll And Yaw Stability of Airplane
amad
amadali is on a distinguished road
Hi, What is the necessary condition for roll and yaw stability of Airplane. Plz Enlist conditions with appropriate reasonings. Explain in simple terms.
amadali is offline   Reply With Quote
Old   January 15, 2025, 03:35
Marc Aragó Cebolla
Marc_462 is on a distinguished road
CMα < 0, CLβ < 0, CNβ > 0
The first inequality tells us that the pitching moment must behave inversely to α (angle of attack). As the angle of attack increases, the aircraft will generate a pitching moment in the opposite direction, bringing it back to its equilibrium point. This point is the trim angle, αtrim. To meet the criterion for longitudinal stability, the center of gravity, xCdG, must be located ahead of the neutral point, xNP. The other two equations describe that at any roll angle β, the roll moment must be restorative, and the yaw moment must counteract disturbances during turns.
IMPORTANT: this is not a CFD question!!!
Marc_462 is offline   Reply With Quote
cfd analysis, stability analysis
Stability of a Projectile (or any AV) CurvingFlow Main CFD Forum 0 August 2, 2022 12:00
moment coefficient (roll, pitch, and yaw) august OpenFOAM Running, Solving & CFD 0 February 9, 2022 07:53
Help with using 6Dof to simulate wing with aileron doing roll, yaw quarkz OpenFOAM Running, Solving & CFD 4 April 27, 2021 03:25
Roll, Yaw, Pitch for External Aerodynamics shereez234 OpenFOAM Programming & Development 1 February 7, 2020 13:30
How to estimate roll, pitch, and yaw moments at once? Geon-Hong OpenFOAM Post-Processing 0 November 21, 2011 23:50
