porous zone parameters - input vs output value
Old   March 20, 2025, 05:47
Default porous zone parameters - input vs output value
mmengineer is on a distinguished road
Hello everyone,
iīm using a porous zone in an open channel flow. The porous zone represents a blockage and stretches over the wohle width of the channel. I am feeding the simulation with a quadratic pressure loss function, so i am only defining values for C2/t.
As a control of input vs. output, i defined report files for the volume averaged water height in the porous zone (calculated over volume averaged volume fraction x height of the porous zone). With the volume averaged height an the known discharge, i can calclate the volume averaged velocity in the porous zone.
Additionally i am monitoring the pressure drop caused by the porous zone, via total pressure at the front face minus total pressure at the back face of the porous zone.
When i am calculating the "output" pressure drop function, as pressure drop over volume averaged velocity, i am not getting exactly the same function as i used as input value. I am observing a small drift, as if there were an additional linear part to the actually solely quadratic input function.
Has anyone encountered a similar prolīblem, or does anyone have an idea why this (small) drift occurs?
I am happy for every help i could get.
A graphic with input and observed output functions is attached.
Regards
mmengineer is offline   Reply With Quote
open channel, porous zone, pressure drop
input and output parameters in workbench Khan_CFD FLUENT 1 July 18, 2024 13:53
How to output porous force in OF221 chery1986 OpenFOAM Post-Processing 15 March 14, 2024 12:44
PEMFC tutorial case problem Suleyman41 FLUENT 2 July 15, 2023 11:16
Simulating particles trapped in porous zone yje1994 FLUENT 5 April 6, 2020 09:15
define porous zone in fluid domain pannsave FLUENT 0 March 24, 2014 07:27
