QUESTION IN GENERATION OF BODY-FITTED MESH
Old   September 19, 2000, 04:06
Default QUESTION IN GENERATION OF BODY-FITTED MESH
James Zhu
When programming a code in generation of body-fitted mesh for a cirque using the Laplace equation,I met a problem: the first,the outputted x and y coordinates are wrong,clearly,the point almost all locate in the secant,especially in the two endpoints(the secant coinsidence with the x-axis) the second,I use multigrid method to solve the system of elliptical equation with the FMG+FAS,5 mesh level are used,on the forth 4 level from the coarsest grid(5) to the finer grid(2),the V-cycle converge very fast,but in the finest grid,the V-cycle converge in the beginning,but donot converge finally(the residual from the Gauss-Seidel iteration is 1.6...,too big),please help me!
thank you!
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
HOW TO GIVE BODY HEAT GENERATION TERM NITUL KALITA FLUENT 3 December 18, 2008 11:23
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
