[Sponsors] | |||||
SnappyHexMesh not conforming the meshing geometry |
Oskar P. Sagatun
Rep Power: 3 ![]() |
I am currently running a setup where i mix blockmesh blocks and snappyHexMesh blocks in openFoam. The mesh consists of a circular straight pipe made with blockmesh and a T-Junction made in a CAD program and implemented with SHM at the pipe outlet.
When meshing this part SHM does not conform to the correct geometry. At the edge between the pipe outlet and junction inlet SHM does not follow the correct geometry creating an indent in the geometry as pictured. This phenomena is present at both the inlet part and the outlet parts as pictured. Currently this junction is being placed at an overlap with the inlet pipe as pictured, when it is not meshed on top of each other but with just a bounding box around the STL the edges are not properly captured. I hope someone is familiar with the problem and has a solution i have multiple pictures and the SHMD file below. https://drive.google.com/drive/folde...JD?usp=sharing |
M
Rep Power: 14 ![]() |
As the same happens at the other sides, i strongly recommend using edge refinement to capture the cylinder edges sharply. Use the surfaceFeatures / surfaceFeatureExtract utilities (depending on which OpenFOAM release you work with).
| Tags |
| bug in openfoam, snappy hex mesh |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [snappyHexMesh] blockMeshDict Geometry And snappyHexMesh | HappyS5 | OpenFOAM Meshing & Mesh Conversion | 0 | August 4, 2019 03:50 |
| [snappyHexMesh] SnappyHexMesh won't snap to geometry (external flow) | JTDN | OpenFOAM Meshing & Mesh Conversion | 4 | July 1, 2019 08:17 |
| [snappyHexMesh] snappyHexMesh creating a box inside my geometry (not supposed to do so!) | ocalloc | OpenFOAM Meshing & Mesh Conversion | 2 | June 9, 2016 11:04 |
| [GAMBIT] spray dryer geometry meshing gambit | deepak11091 | ANSYS Meshing & Geometry | 1 | October 29, 2015 03:07 |
| Reg difficulties in meshing the geometry...Urgent | arunraj | ANSYS Meshing & Geometry | 0 | August 27, 2011 00:25 |
