How Detonation wave behaves in microgravity?
Like Tree2Likes
  • 2 Post By FMDenaro
Old   September 15, 2025, 02:53
Default How Detonation wave behaves in microgravity?
hm
huzaim is on a distinguished road
I want to simulate the combustion on Ansys at near 0g microgravity. I am unable to sort out that I should start from where. Main objective is to study the detonatoin wave behaviour in space/microgravity. Can anyone help me in detail. Very less online resources are availbe for this. I request you to guide me so I can study in depth.
huzaim is offline   Reply With Quote
Old   September 15, 2025, 04:27
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
In absence of atmosphere (no combustion) is impossible, do you imagine a controlled environment like in the ISS?
FMDenaro is offline   Reply With Quote
Old   September 15, 2025, 04:55
hm
Yes dear sir , you are right. I meant to say that in controlled enviornment with fuel and oxidizer feed system. I am confused that where to start. I know th effect of microgravity on flame but don't really understand how to simulate it in ANSYS.. only limiting g vector will serve this purpose or not?
Old   September 15, 2025, 05:04
For sure you have to set g tending to zero.
In general microgravity fluid dynamics, other effects appear relevant due to Marangoni effect. In your case I don’t think they would be relevant.
Old   September 16, 2025, 07:50
Gerry Kan's Avatar
Gerry Kan
Gerry Kan is on a distinguished road
You might also want to look at the early works pertaining to (spark) ignition - e.g., in the 1980s, and some of the works on premixed ignition modelling. They focused at the time before gravitational effects become significant. This should give you an idea how to proceed.
Fillipo is right, depending on the prevailing turbulence, you should expect the flame front to form cells due to a combination of temperature and concentration inhomogeneities resulting from ambient interaction. I don't know if these are your points of interest.
Another thing to consider it the characterization of turbulence in ANSYS. That is, whether you are expecting an initially quiescent condition. All I can say is, if this is the case, you cannot use a RANS approach because this will grossly overpredict the flame speed, and I am speaking from experience. You will need to use LES so more correctly capture the transition to turbulence.
You will need to think through how you are setting up your model, i.e., under what conditions you will be conducting these runs. Especially due to turbulence representation I have mentioned before, it is not as straightforward as it seems.
Hope it helps, Gerry.
Gerry Kan is offline   Reply With Quote
Old   September 17, 2025, 04:38
hm
you are right sir. I am not very much expert in CFD. I am assigned to investigate the effect microgravity on rotating detonation engine. I am struggling to find good literature on it. Yeah,you're feedback somehow showed me path. I am mech undergrad student. if you want to add more pls. It will really help me. I just need right direction.
Old   September 17, 2025, 08:38
bigfoot
bigfootedrockmidget is on a distinguished road
A recent paper with some computational details can be found here:
Peng and Deiterding (2025)
https://www.sciencedirect.com/scienc...66352X24000712
They do not use a gravity source term, because buoyancy is often not important in combustion (exceptions are e.g. pool fires, or candle flames where the air draft is important).
In any case, from this paper it looks like you can get pretty decent results with limited computing time, less than 1,000 cpu-hrs for a computation on a 1M cell mesh, and it's only second order.
bigfootedrockmidget is offline   Reply With Quote
Old   September 17, 2025, 09:15
The real problem is that an undergaduated student should not have been assigned such a problem only because there is Ansys…
Gerry Kan and huzaim like this.
Old   September 17, 2025, 10:24
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
True story, unfortunately, it is not the only one. This is my main complaint about robust (in the sense of "running" things) commercial solvers, they make it look like it is mostly a pre-proc interface issue by hiding the elephants which are the solvers and couplers.
Nonetheless, this artificial aid has led many to the CAE area. Once here, some fell in love and face the endless updates whereas others leave to live a more "normal life"
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Old   September 18, 2025, 05:20
Gerry Kan's Avatar
Gerry Kan
When I saw your original message I had a very different understanding on what you are trying to do. Given this topic, you should understand that this is a very complex problem involving chemical kinetics, thermoacoustics and shock wave propagation (from detonation). I don't think for what you want to do this is appropriate technically at an undergraduate level.
Are you sure you are not asked to simply write a 10-page (literature) review on this, whereupon a fully working numerical model is only "nice-to-have"?
Old   September 19, 2025, 06:25
hm
You’re absolutely right, sir. I have to work on this myself, so I’m going through all the available literature and research papers. Due to the absence of buoyancy and gravity, it’s still uncertain whether a detonation wave will even form. And even if it does, there’s no guarantee it will remain sustained. There are many complex factors at play simultaneously. But with proper guidance from you and other experienced people, I’m hopeful that we’ll be able to achieve meaningful results.
detonation tube, microgravity
interFoam wave propagation and explosion of Courant number and residuals ChiaraViola OpenFOAM Running, Solving & CFD 1 June 26, 2019 06:36
[waves2Foam] Waves2Foam Related Topics ngj OpenFOAM Community Contributions 660 August 20, 2018 13:39
Jet Engine case, initiating a detonation wave, and reactingParcelFoam errors HRobertHS OpenFOAM 2 March 11, 2017 21:23
Starting With A Detonation Wave HRobertHS OpenFOAM 2 March 8, 2017 16:29
detonation wave simulation Krish FLUENT 15 February 7, 2017 13:38
