September 28, 2000, 02:04 |
loss in force
I calculated for test-purposes a very simple 2d-problem: a channel with length l and symmetry, velocity-inlet and an outflow. I used the standard-wall-model and k-eps. The y+ are between 150 and 300 and ok. Now the problem: If I take the shear-force at a part of the wall (the flow is developed) I get 3.3 (dimensionless) The other way would be to calculate it by hand:
F_res=rho*c1**2-rho*c2**2+p1*A1-p2*A2 with c1=c2 and A1=A2, I get: F_res=A*(p1-p2) If I sum up the area-weighted pressure at the positions 1 and 2 I only get 2.6 as the resulting force. It seems, I lost about 0.7..where are they ? |
September 28, 2000, 08:56 |
Re: loss in force
(1). Check the equation first, where did you get this equation?
September 28, 2000, 17:13 |
Re: loss in force
ok. error in the equation, sorry. It should be rho*ci**2*Ai (!!), and if I sum it up in the correct integral (!) form, i get the correct result...
September 28, 2000, 17:18 |
Re: loss in force
(1). Congratulation! (2). I wasn't so sure when I answered your question. So, You should say, you found your own errors.
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
User-defined force transfer across FSI interface | vivekcfd | CFX | 7 | March 10, 2010 20:43 |
Urgently Need the code of Lift force and VM force | Kai Yan | Main CFD Forum | 0 | July 16, 2008 07:07 |
DEFINE_CG_MOTION and pressure force | Teo Fumagalli | FLUENT | 0 | April 11, 2008 10:25 |
pressure force and viscous force | CFD | FLUENT | 0 | March 7, 2006 01:03 |
