Validation of flow around rotating cylinder
Old   October 9, 2000, 11:34
Default Validation of flow around rotating cylinder
Marat Hoshim
Hi all,
for validation reasons I'm looking for some experimantal values of cd and cl of a flow around a rotating cylinder.
If someone knows a refenrence for that, I would be glad if he/she would let me know.
Thanks,
Marat
Old   October 10, 2000, 13:09
Default Re: Validation of flow around rotating cylinder
frederic felten
Hi there,
Check the following publication,
"Turbulent flow around a rotating cylinder in a quiescent fluid". Dierich, M.; Gersten, K.; Schlottmann, F. Experiments in Fluids v 25 n 5/6 Oct 1998, p 455-460.
Abstract: Hot-wire measurements have been carried out in the turbulent flow around a rotating circular cylinder in still air for Reynolds numbers Re = varies directly as Uw|D/ν = 1.5×104 to 105. The experimental results confirm the analysis derived by asymptotic theory for high Reynolds numbers. Two different ways of deriving the friction law from the experiments (via shear stress and via velocity distribution) resulted practically in the same law. It is shown, that in spite of the curvature of the streamlines the universal logarithmic velocity distribution is still valid near the wall.
I hope this will help. Sincerely,
frederic felten
2D modelling of flow past a rotating cylinder pds24 Main CFD Forum 1 August 21, 2015 10:50
Incompressible, Unsteady Cylinder Flow startingcfd Main CFD Forum 1 March 15, 2011 01:12
Reverse Flow at Rotating Pipe Outlet vismech STAR-CCM+ 1 August 11, 2009 10:38
PROBLEMS WITH ROTATING FLOW BETWEEN TWO CYLINDERS vitmalin CFX 2 October 11, 2006 07:22
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
