Transonic Test Case
Old   October 18, 2000, 11:57
Default Transonic Test Case
Scott Holloway
I am looking for a test case that examines transonic flow conditions (shocks, etc.) in an airfoil cascade. I would like references for an experimental study or a good CFD study that uses an experimental validation case.
I do not need anything complex.
I have heard of a standard benchmark transonic case. I believe it is called the (Ni-bump). If you know of a reference for this that would also help.
Thanks
Old   October 19, 2000, 16:46
Default Re: Transonic Test Case
clifford bradford
I did see in a research report from the VKI (von karman institute) where they compared numerical result to an exact solution of the euler equations over a cascade. send me an email and I'll remember to get it for you
Old   October 31, 2000, 13:35
Reaz Hasan
Another well documented and widely used test case is Flow over a transonic bump by Bachalo and Johnson, AIAA J, v24, (437-443), 1986.
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 06:35
bump test case moein_joon27 Main CFD Forum 0 April 29, 2011 04:51
Help Required With Simple Test Case steph79 OpenFOAM Pre-Processing 4 August 3, 2010 07:45
looking for a test case, DES, Supersonic flow kaarthik Main CFD Forum 0 June 7, 2007 05:49
Test Case ganesh Main CFD Forum 0 March 16, 2006 12:34
