Parallel Processing by FLUENT?
Old   February 19, 2001, 12:03
Default Parallel Processing by FLUENT?
M Kermani
Hi dear scholars,
We have a version of fluent (5.xx) in our school and I need to do parallel processing by FLUENT on the cluster of PC.
I wonder if someone can let me know what are the procedures and are there any extra files that we will need to download.
Regards. M
Old   February 20, 2001, 10:48
Default Re: Parallel Processing by FLUENT?
Johan Larsson
OK, see if I remember it correctly...
1) Start Fluent by command "fluent"
2) Under File, click "Run"
3) Specify parallel etc. You probably have to use "socket" for the message passing, since you may not have mpi on your machines.
4) You may have to specify what machines you want to use manually under "Parallel" or something like that.
5) Proceed as per usual.
I haven't done it for a while, so the commands may not be exactly what I wrote!
/Johan
Old   February 21, 2001, 10:01
K. Tsai
For PC clusters, you need to set up a file in your home directory called ".fluent.hosts" in which the machine names are specified. Then start FLUENT using the command "fluent 3d(or 2d) -pnet -t0" and follow the steps below:
1. Click Parallel-> Network -> Configure 2. Highlight the machines you want to run your parallel job (no more than 8 nodes at a time), 3. Click Spawn at the bottom.
If you need more than 8 nodes, repeat the above steps for more processors. I believe this is a bug in Fluent.
Good luck.
Parallel Processing on ANSYS FLUENT 12 srr FLUENT 2 April 16, 2011 14:16
Grid Check Fails in Parallel Processing Mode askance Main CFD Forum 0 October 20, 2010 10:11
Fluent Parallel Processing Mrxlazuardin FLUENT 2 April 28, 2010 07:36
Fluent parallel poovanna FLUENT 0 March 23, 2007 23:22
Parallel Fluent on Linux clusters Chengwang Lei FLUENT 3 November 24, 2004 02:05
