Star-HPC
Old   May 12, 2001, 14:42
Default Star-HPC
Roued
Hi
I am currently investigating how to build a good cluster of computer in order run Star in parallel.
Does anyone have experiance one what does performe the best: each node in the cluster should be a single CPU computer or Dual CPU computer ?
What about the parallel speed up have been obtained ?
What kind of network have been used ? (Ethernet 100 or 1000 or ???)
Comparison between PC system (Inlet/AMD CPU) and other UNIX kind computer nodes like (HP, SUN, Compaq) ?
Kind Regards
Roued
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Running Star From Command Line in HPC A.S. Siemens 4 May 19, 2005 08:28
how to set star HPC environment in Linux? dorain Siemens 1 November 20, 2004 07:14
STAR HPC. Problem with COMMON BLOCK Denis Siemens 0 April 4, 2003 07:33
