SOS!About water-vapor
Old   May 11, 2001, 22:35
Default SOS!About water-vapor
max
Hi, everyone! IĄŻm modeling water-vapor flows through a converge-diverge nozzle using commercial code. For compressible flows, many commercial codes think the idea gas law is the appropriate density relationship. However, the water vapor IĄŻm using is 0.6Mpa, so in my opinion, it canĄŻt be thought as idea gas. Unfortunately, I couldnĄŻt find the UDF (User Defined Function) for density. Could anybody kind enough to give me some advices on how to set the physical properties. Anything about FLUENT, CFX, or ANSYS is welcome! All thanks given to you for your help!
Old   May 14, 2001, 08:55
Default Re: SOS!About water-vapor
Darcy Jiang
Doesn't USRDEN in CFX-4 help you?
Old   May 15, 2001, 07:22
max
Thank you for your help. I had found the UDF(user defined function) in FLUENT.(because i am more familiar with that code). Now my question is how can i decide the state of the fluid on the basis of the temperature which is equal to that of the saturated water-vapor?
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Help with mass transfer in heat and water vapor exchanger mullenc525 CFX 7 January 25, 2011 23:26
Injection of water in vapor SimoneTecnoil FLUENT 0 November 10, 2009 09:32
Injection of water in vapor SimoneTecnoil FLUENT 0 November 9, 2009 11:29
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
