nUMECA UNSTEADY SOLVER
Old   May 16, 2001, 05:19
Default nUMECA UNSTEADY SOLVER
dimitris
Hi I was wondering if anybody know a way to estimate how many inner iterations i need to use in an unsteady flow problem using NUMECA Solver and if its possible to estimate a reduction to the inner iterations number according to the residual diagram.
Old   May 16, 2001, 10:28
Default Re: nUMECA UNSTEADY SOLVER
Bruno
Dimitri,
The number of inner iterations required depends on the physical time step. If you use a very small physical time step compared to the characteristic time scale of your problem (for example the period), then you might only need bout 20 to 30 inner iterations per time step. If you double the physical time step then your might need to double also the number of inner iterations to reach the same convergence level.
Usually we observe that, at each physical time step, a convergence of about 1 to 2 orders of magnitude is necessary and sufficient to trust the solution.
If you need any additional help, do not hesitate to contact us at support@numeca.be
Bruno
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
On Setring Step Size in unsteady Solver of FLUENT lzgwhy FLUENT 0 August 19, 2009 22:44
Problems with unsteady transonic solver Frank Main CFD Forum 0 July 24, 2006 13:48
Steady and unsteady solver sam thompson FLUENT 1 April 20, 2006 12:39
