finite volume ale method
Old   May 27, 2001, 15:51
Default finite volume ale method
mohsen
hi my thesis is about simulation metal casting flow with ale method(finite volume) please give me some refrence when we use lagrangian method why the convective terms neglected? thanks111111fsfs
Old   May 27, 2001, 16:24
Default Re: finite volume ale method
bronze
I hope this is not what you are refering to...
DA/Dt = dA/dt + u dA/dx
Old   May 27, 2001, 20:12
Jongdae Kim
Maybe you use moving mesh technique.
Case1 : Nodal point and material point move together. (This is the same case of Lagrangian description.)
The two points have the same position throught the simulation. So there is no convection through the mesh surface.
Case2 : The speed of flow through the control volume surface is very small.
You can neglect the convection term. Diffusion term is more important.
gradient calculation of cell centered finite volume method zhengjg Main CFD Forum 10 November 11, 2012 23:13
finite volume method - lid driven cavity ainal Main CFD Forum 0 May 15, 2011 11:06
Control Volume , Finite Volume, Finite Control Volume, Finite Element Method technocrat.prakash Main CFD Forum 1 April 24, 2010 19:24
Sparse linear systems in finite volume method Lionel S. Main CFD Forum 6 January 19, 2007 10:04
finite volume method for CFD analysis of 2D blunt body Aditya Vaze Main CFD Forum 1 January 19, 2000 13:55
