Question concering about validating Temperature field
Old   December 1, 1998, 11:58
Default Question concering about validating Temperature field
ghlee
I simulated a flow in a vehicle passenger compartment . My final target is to obtain temperature field. Thus I wish to validate my code in solving temperature field. What is the most proper test problem? Could you give me answer? Thank you
Old   December 1, 1998, 13:36
Default Re: Question concering about validating Temperature field
John C. Chien
Just find a thermometer and climb into a car , then turn on the air conditioner and start measuring the temperature at several different places. I think this real world approach is easier and better because it is not easy to get everything modelled in the simulation. Have a friend to measure the temperature when you are driving. ( you don't have to follow my suggestion, instead of turning on the air conditioner, you can turn on the heater instead.)
Adding Temperature field to IcoFoam yapalparvi OpenFOAM Programming & Development 14 November 19, 2015 05:57
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
problem with temperature field in modeling evaporation with fluent MOhaj FLUENT 0 April 25, 2010 00:54
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Pipe wall temperature Fred Uckfield Main CFD Forum 25 May 22, 2000 15:37
