Suggest a post processor for visualisation
Old   June 13, 2001, 01:35
Default Suggest a post processor for visualisation
Mukhopadhyay
I think the title is sufficient - please add : vectors and contours (2D). Thanks in advance
Old   June 13, 2001, 04:02
Default Re: Suggest a post processor for visualisation
Jing
I think Tecplot is a strong post-processor.
Old   June 13, 2001, 04:46
Kike
Hi, Mukhopadhyay
If you use Windows TECPLOT is Ok but it is not free.
Otherwise, try to use any Linux distribution and you will see the great performances of a free source codes such as: popiplot (http://www.lmm.jussieu.fr/MEMBERS/PO...lot/index.html
or Vis5D (at rpmfind.net I think). Good luck
Kike
Old   June 13, 2001, 05:36
Bart Prast
Use Fieldview
Old   June 14, 2001, 14:54
Dr Strangelove
There are a lot of possibilities, a few of which have already been mentioned by other responders to your query.
Two additional possibile alternatives you may wish to consider are these open source packages.
  1. vtk (see, too, MayaVi)
  2. dx
Old   June 14, 2001, 19:24
clifford bradford
Matlab is a good choice. You can probably find some cheap/free ones also at http://SAL.KachinaTech.COM/index.shtml
Old   June 15, 2001, 06:33
Default THANKS!!!
Kike
Ansys Post processing ano999 ANSYS 1 May 27, 2011 16:24
NO model vs post processing in coal combustion,CFX sakalido CFX 1 April 15, 2011 14:07
Export from post gives different result between v11 and v12 bennn CFX 2 February 10, 2011 05:38
Proper output of angle of attack in CFX post Kevin CFX 3 October 18, 2006 12:18
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
