chemical vapour deposition
Old   August 1, 2001, 11:52
Default chemical vapour deposition
Rajani Kumar
Hi, I am doing Ph.D in turbulent combustion. I would like to know about chemical vapour deposition. Please give me suggestions regarding books and papers which are covering introduction to this topic and also modeling techniques. thanks in advance. by rajani
Old   August 2, 2001, 06:14
Default Re: chemical vapour deposition
Michael Malin
Two references are:
Modelling of CVD of Tungsten Films, C.R. Kleijn & C.Werner, Birkhauser, 1993, ISBN 0-8176-2858-4
CVD: Principles & Applications, Ed. M.Hitchman & K.Jensen, Academic Press, 1993, ISBN 0-12-349670-5
In my limited experience of CVD processes, they are laminar rather than turbulent.
Old   August 2, 2001, 08:46
Rajani Kumar
thank you very much for your references. can you please give me some web based references for CVD.
Old   August 2, 2001, 09:15
Michael Malin
There is some information at the following web addresses:
http:http://www.cham.co.uk/phoenics/d_pol...oen/runcvd.htm
http://www.sandia.gov/1100/CVDwww/CVDSci.htm
Other addresses can be determined by use of a search engine on the internet.
Old   August 3, 2001, 03:49
Rajani Kumar
thank you very much.
Old   August 8, 2001, 03:01
Vijay Pargaonkar
Dear Rajani Kumar,
Go to Colorado universities site. See the work done by Roop Lal Mahajan. He has published many reviewes and papers on CVD. Those are in very lucid language and informative.
Pargaonkar Vijay
Old   August 8, 2001, 06:36
Rajani kumar
dear Vijay, thanks for your help. can you please give me some information related CVD on web. if you know any site which is having some notes on CVD then please tell me. by rajani
Old   August 14, 2001, 12:36
Simon Moore.
Out of shear ignorance, what do CVD and Turbulent combustion have in common? Thank you!
Old   August 17, 2001, 15:09
Chuck Leakeas
Simon,
What's in common between CVD and combustion problems is mainly that both flows are chemically reacting and need some method to incorporate the chemical kinetics of the reactions into the flow field. CVD also needs to incorporate surface reactions into the model where combustion problems normally are not concerned with this. CVD problems are strictly laminar flows which are incompressible, where as combustion problems are mainly turbulent and compressible.
Chuck
Old   August 18, 2001, 12:44
Rajani kumar
hi, upto know CVD is treated as a laminar process. But now people are started to think in terms of turbulence. some europien universities are participating in this one. by rajani
Old   August 23, 2001, 13:33
  #11
Madhukar M. Rao
A search on google.com gives about 61,600 hits for Chemical Vapor Deposition.
Cheers, Madhukar Rao
chemical reaction parameters for SiO2 deposition Jiuan FLUENT 3 August 18, 2009 01:01
chemical vapor deposition philip FLUENT 0 March 17, 2002 13:35
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
chemical vapor deposition Paul Izabel FLUENT 0 May 7, 2001 05:45
Chemical Vapor Deposition problems??? Chuck Leakeas Main CFD Forum 1 September 3, 1998 16:35
