Expanding meshes
Old   September 5, 2001, 14:04
Default Expanding meshes
Prashant
Dear all, I'm interested in some biomedical applications of CFD, in which the flow cavity or geometry itself changes w.r.t. time. I am looking for a CFD code that can handle this expansion and contraction of meshes. Is FIDAP the only code in market that can handle this? R there any other codes that deal with these kind of "flexible geometries"? Which is better? Thanks in advance.
Old   September 5, 2001, 18:28
Default Re: Expanding meshes
Astrid
There are several commercial packages that can do the job. I work with CFX 4.4 which can handle the contraction and expansion.
Good luck, Astrid
Old   September 5, 2001, 22:45
Raza Mirza
CFD-ACE+ from CFD Research Corporation (http://www.cfdrc.com) can handle this problem easily. Surface deformation can be prescribed in terms or functions or they can be calculated based on fluid forces if you are interested in fluid-structural interaction.
Visit there website and you will find some interesting biomedical applications. One of them may exactly match what you are looking for.
I also attended Fluent's automotive user group meeting this year. They are claiming beta capabilities with moving meshes in version 6. It is however developed largely with the moving pistion-cylinder type applications.
Old   September 6, 2001, 06:17
Andrew Parker
As far as I am aware Fluent 6 will do this, I have had a presentation on this for a different application, and I think it will apply to you.
Andy
Old   September 6, 2001, 07:17
Amita
Fluidyn series of software (commercialized by Transoft) are designed to couple CFD with structural deformation (solving FV& FE simultaneously, either for thermal or mechanical deformation). You can visit Transoft's Website www.fluidyn.com or contact me for a small mesh expanding case demo.
Amita
[Technical] Automatic Mesh Refinement and Tetrahedral Meshes philippose OpenFOAM Meshing & Mesh Conversion 8 May 21, 2016 16:44
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 08:06
[ICEM] how to create meshes of conformal nodes? snailstb ANSYS Meshing & Geometry 2 March 12, 2010 04:23
IcoDyMFoam and tetrahedral meshes ulrich_lange OpenFOAM Running, Solving & CFD 11 April 16, 2007 17:44
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 04:33
