convergence
Old   September 11, 2001, 03:33
Default convergence
sreekanth
What is the efect of cell size on convergence rate, using unstructured grid.
Old   September 11, 2001, 05:14
Default Re: convergence
Jin-Wook LEE
Ingeneral, cell size itself has not the major effect on the convergence. But, in general, coarse grid has better convergence. Mesh skewness, edge ratio(dx_i/dx_(i-1) ...) and aspect ratio have critical effect on the convergence.
Sincerely, Jinwook
Old   September 11, 2001, 22:13
Dan Williams
What type of convergence do you mean in this case? Convergence to a mesh independent solution, which is somewhat tricky to guage on an unstructured grid. Or, convergence of residuals of algebraic equations?
Dan.
Old   September 12, 2001, 03:38
sreekanth
The convergence in FEM used to unstructured grids is of the order of cube of h(cell size parameter,less than 1.0).
What is the trend in FVM used to unstructured grid?
Old   September 12, 2001, 05:12
Kang, Seok Koo
The convergence always depends on the CFL number when we use explicit scheme. CFL number on unstructured grid generally depend on the volume/area of a control volume.
When the mesh size is very small, the time step must be reduced to get the converged solution.
In my experience, if a mesh is not highly stretched, geometry of a mesh is not an important factor.
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
