Grid generation package confined to turbomachinery |
September 4, 2001, 14:10 |
Dear collegues.
I am calculating tip clearance flow in axial type turbomachinery. Because I used the low Reynolds number turbulence model, very dense grid with clustering near the wall is needed. I tried to generate mesh bu using commercial package, but I could not obtain any satisfactory results. Therefore, I determined to order the package and, if possible, please let me know your suggestions. Thank you |
September 4, 2001, 16:39 |
Re: Grid generation package confined to turbomachi
If you need a high quality (hex) mesh with suitable spacing at the wall then you should have a look at GridPro.
September 5, 2001, 05:40 |
There is also Tiger from Catalpa. You can download even a demo online and test if it is suitable for your application
September 5, 2001, 08:29 |
IGG/Autogrid from NUMECA can certainly help you. This meshing tool is specifically dedicated to turbomachine and tip clearance modelisation can be performed.
September 5, 2001, 10:04 |
The meshing tool IGG/Autogrid from NUMECA will help you a lot. It is dedicated for meshing on turbomachines and affords to modelize tip clearances.
September 5, 2001, 17:38 |
TascFlow from AEA Technology is designed for turbomachinery.
September 6, 2001, 05:34 |
You could also look at ICEM CFD HEXA. For more info see, http://www.icemcfd.co.uk Or email me davidm@icemcfd.co.uk If you have more detailed questions. Regards David ICEM CFD Engineering |
September 18, 2001, 12:33 |
"G/Turbo", a new preprocessing tool from Fluent is specially designed for Turbomachinery applications. It allows modeling of Tip clearances, and generates high quality mesh with nice boundary layers.
Display Modes | |
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 03:33 |
elliptic grid generation | prapanj | Main CFD Forum | 1 | November 19, 2007 16:53 |
3D Hyperbolic Grid Generation - Help Requested... | Marcus Lobbia | Main CFD Forum | 2 | November 9, 2003 05:53 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
Latest news in mesh generation | Robert Schneiders | Main CFD Forum | 0 | March 2, 1999 04:07 |
