moving boundary and pressure
Old   September 20, 2001, 03:28
Default moving boundary and pressure
M. Engel
I am using curvilinear coordinates to solve the ALE-Navier-Stokes-equations on a moving grid. Grid velovities are computed according to geometric conservation. A pressure projection method is used. At inflow boundary a constant(in time) parabolic profile is used, freestream at outflow boundary and no-slip(v=0) at rigid walls. At the moving wall I set u = u_wall. Now I experience pressure oscillations(in time), apparently dependent on the acceleration of the boundary, and after long time the poisson-equation is not solvable any more. Any hints?
Thank you, Martin
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
