On SIMPLE algorithm in compressible flow situation
Old   October 11, 2001, 00:26
Default On SIMPLE algorithm in compressible flow situation
Abhijeet Vaidya
Respected sirs, As per the derivation of pressure correction equation in Patankar's SIMPLE algorithm,the density corrections are not directly incorporated. This makes the SIMPLE best suited for the incompressible calculations. Can I use this formulation for compressible subsonic flows directly ? e.g. flame propagation in a premixed fuel air mixture without detonation! Or in other words, where do I have to introduce density corrections, at M > 0.3 or at M >= 1. Thanking you !
Old   October 12, 2001, 06:55
Default Re: On SIMPLE algorithm in compressible flow situa
Peter
In the continuity equation, the mass is
mass = density(new)*velocity(new)*area
= [density(old)+density(correction]*
[velocity(old)+velocity(correction)]*area
~={density(old)*velocity(old)+
density(old)*velocity(correction)+
density(correction)*velocity(old)}*area
velocity(correction)~ p(correction)
density(correction)~ p(correction) through
equation of state That is, you have extra term in pressure correction equation due to density change.
Reference paper: <A collocated finite volume method for predicting flows at all speeds> by I. Demirdzic etc, International J. for Numerical methods in fluids Vol. 16, p1029-1050, 1993
Old   October 15, 2001, 02:20
Jean van der Merwe
I searched for this article, but could not find it. Peter, can you help me. I would like to expand this formula to the Piso algorithm. This will also be used to enable the modelling of subsonic compressible flow.
Thanks in advance Jean
Old   October 18, 2001, 05:46
Peter
The title of the paper is:
A Collocated Finite Volume Method for Predicting Flows at all Speeds
by I. Demirdzic, Z. Lilek and M. Peric
If you really can not find it, pass me your Mail address or fax number to Luojia2000@aol.com, I may give you a copy.
code for SIMPLE algorithm - 2D Lid driven cavity flow problem - Collocated grid h_amooie OpenFOAM Programming & Development 1 January 22, 2022 11:33
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 11:34
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
Compressible de Laval Nozzle Flow rw511 CFX 3 May 22, 2011 19:48
who knows compressible SIMPLE algorithm? peck110 Main CFD Forum 3 February 5, 2008 09:34
