C code for node renumbering?
Old   November 25, 1998, 17:27
Default C code for node renumbering?
Matthew Cordery
Anyone out there have any C code for node renumbering of a finite element mesh? (It's for bandwidth reduction)
Old   December 21, 1998, 06:10
Default Re: C code for node renumbering?
Aldo Bonfiglioli
the PETSc developpers have translated F77 code from sparspack (I believe) into C using f2c; it's now part of the PETSc library http://www.mcs.anl.gov/Projects/petsc/petsc.html.
For some time I' ve been using:
ALGORITHM 582, COLLECTED ALGORITHMS FROM ACM. ALGORITHM APPEARED IN ACM-TRANS. MATH. SOFTWARE, VOL.8, NO. 2, JUN., 1982, P. 190. (http://www.math.psu.edu/dna/contents/toms.html)
which is in F77, but translating it into C should pose no problems, I believe.
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 12:30
Open Source Vs Commercial Software MechE OpenFOAM 28 May 16, 2011 11:02
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 10:11
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
own Code vs. commercial code Bernhard Mueck Main CFD Forum 10 February 16, 2000 10:07
