November 3, 2001, 03:40 |
Elliptic meshing generation
please recommend some simple code. I am entry-learner.
November 5, 2001, 23:27 |
Re: Elliptic meshing generation
I wrote an elliptic mesh generator many years ago, based on four different numerical methods. Unfortunately, I no longer have the report, otherwise I would send it to you (the source code would not help you; I don't even understand it anymore).
Elliptic grid generators are based on Laplace's or Poisson's equation (P = L + source term). In essence, you are solving a (2-D) heat conduction problem, and your converged mesh consists of lines of constant temperature (isotherms) intersected normally by flux lines. There are several ways to solve the Laplace or Poisson equation numerically. In increasing complexity, these are, SG-SOR SG-ADI MG-SOR MG-ADI where, SG = Single-Grid MG = Multi-Grid SOR = Successive Over-Relaxation ADI = Alternating Direction Implicit You should be able to find references to these methods in the literature. A good starting point for elliptic mesh generation is Chapter 5, "Computational Fluid Dynamics - The Basics with Applications", by John D. Anderson, Jr. |
November 7, 2001, 02:08 |
Mr.Axel,is it that the generated mesh can be used for all kind of discretisations.I am a finite element follower.Regards,asoksp
November 8, 2001, 07:48 |
Certainly! The elliptically generated mesh has quadrilateral cells. Most FE analysts prefer triangular cells, which can be obtained by simply cutting the quadrilaterals at opposing corner points.
Display Modes | |
elliptic grid generation | prapanj | Main CFD Forum | 1 | November 19, 2007 16:53 |
meshing generation services | mohr76 | Main CFD Forum | 7 | February 22, 2007 05:30 |
Proposal w.r.t. Meshing & Mesh Generation articles | jasond | CFD-Wiki | 3 | October 18, 2006 19:03 |
Elliptic Grid Generation | R.V.Ramkumar | Main CFD Forum | 2 | July 5, 1999 11:06 |
Latest news in mesh generation | Robert Schneiders | Main CFD Forum | 0 | March 2, 1999 04:07 |
