How to deal with the nonlinear convective term?
Old   December 6, 2001, 09:10
Default How to deal with the nonlinear convective term?
D.Yang
I am a novice. I try to solve primitive variable Navier-Stokes Equation using projection method in combination with multigrid. Without introducing turbulence model. I don¡¯t know how to deal with the nonlinear convective term of the momentum equation before iteration. Who can help me? Thanks. David Yang
Old   December 8, 2001, 13:41
Default Re: How to deal with the nonlinear convective term
Junseok Kim
Usually people use it as a source term, so by using Taylor expansion and high order Godnov upwind method, you can get, convection term at time n+1/2.
Old   January 16, 2002, 16:24
kenn
on introductory level of CFD, nonlinearity is nothing.
in FDM, one simple idea to deal with nonlinear terms in time dependent problem: for example, f(u) du/dx, treat f(u) as something known at time n+1, which can be calculated from data at time n; du/dx is discretized at time n+1.
but, later on, you'll find out it's nonlinearity that causes CFD much harder than computational solid mechanics.
RAS Turbulence Models - Convective Term john_w OpenFOAM 3 May 29, 2010 21:31
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
How to suppress the convective term SAKTI Siemens 1 August 28, 2008 01:38
Convective term evaluated at time n+1/2 Lionel S. Main CFD Forum 0 February 12, 2007 14:22
How to deal with sourse term Du Main CFD Forum 2 April 8, 2001 09:07
