Procedure to run unsteady simulation?
Old   February 15, 2002, 01:59
Default Procedure to run unsteady simulation?
STN
Dear all I am extending my code from steady simulation to unsteady simulation. I want to know the procedure to run unsteady simulation.
First, What is the starting guess to run the simulation? Can I use stagnant fluid?
Second, When do I start to average the results?
Any suggestion is very please to me.
Thank you in advance.
STN
Old   February 15, 2002, 15:10
Default Re: Procedure to run unsteady simulation?
Linda
Often the start is a dirty, or incompletely converged steady solution.
Start the time-average when the start up transients have dissapeared. Monitoring a parameter such as drag can help you decide when this occurs. About 3 - 10 characteristic lengths, or the time for a particle to travel past the geometry about 3 - 10 times, is usually required. Reflective boundary conditions can make this time longer.
I make my time-averages very long for good accuracy, 50 - 100 characteristic lengths. This depends on how chaotic the flow field is.
Old   February 16, 2002, 04:37
STN
Hi Linda
Thank for your response.
Anyway, you say that the starting guess may use an incompleted converged solution of steady flow. Is it mean that it is impossible to simulate the starting flow ?
And How long is the computation time that you used to get an good accurecy average results?
Thank you STN
What's the best order to run this simulation in? siw CFX 1 November 4, 2009 19:42
Unsteady simulation on the flow around Naca0012 Peter Pan Zhang FLUENT 2 June 11, 2006 19:53
save data in unsteady simulation Guillermo FLUENT 1 February 17, 2006 09:59
Unsteady simulation of flow past wheel Tom FLUENT 8 January 18, 2006 10:54
unsteady simulation of wind turbine---please help bharat FLUENT 0 November 7, 2005 00:02
