Multiphase data
Old   February 18, 2002, 07:05
Default Multiphase data
Jon
I have set up a spreadsheet which predicts two phase flow patterns, pressure drop, etc. in an annulus. Does anyone know of any available (preferably online)experimental data with which I can test the accuracy of my spreadsheet? Thanks in advance.
Old   February 19, 2002, 02:57
Default Re: Multiphase data
jesus moreno
Online experiment:
http://che-lab.cheme.columbia.edu/
Our laboratory is actually working in two-phase flow patterns, heat transfer and pressure drops in horizontal tubes.
Which kind of model are you using ?? .. What do you mean with:
?I have set up a spreadsheet which predicts two phase flow patterns, pressure drop, etc. in an annulus?
Old   February 19, 2002, 03:50
Jon
I'm using Fluent's VOF model, in attempt to see the main horizontal two phase flow patterns. As a form of validation, I've implemented a spreadsheet based on mechanistic models published in the literature (they are all generally derived from Taitel & Dukler's 1976 model). The spreadsheet attempts to predict the flow pattern, then apply the appropriate pressure drop equation.
Old   March 10, 2002, 07:56
remy
Hi Jesus,
I send you this mail 'cause i am working on the reduction of drag of a yacht ship (on Fluent). I would like to use the VOF model in order to modelise the steady waves of the free surface. Could it be possible for you to tell me the configuration i have to set up for this multiphase modelisation (boundary conditions, initialization,multiphase set up, etc...) ps:I use a steady ,ke model. I thank you for your help. Regards, Remy.
export data at nodes Meenu FLUENT 1 December 30, 2011 01:24
Use data from multiphase into DO radiation yashmash FLUENT 0 October 7, 2011 03:57
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
Multiphase experimental data James McLaren Main CFD Forum 1 September 14, 1998 06:35
