March 22, 2002, 03:48 |
Fluent animation commands
Hi I'm a 3rd year Aerospace student at the University of Manchester and looking at vortex shedding from a cylinder in fluent 5.5. I'm having problems generating the tiff files in order to animate the flow. Does anyone know the commands ( solve - monitors - command) to automaticaly create a tiff file and then save the picture? any help would be much appreciated.
many thanks |
March 22, 2002, 04:12 |
Re: Fluent animation commands
This belongs on the Fluent Forum.
I think that you can find the answer in the archives - use the site-wise search engine and search for "quality fluent movies". |
March 22, 2002, 07:36 |
I am using NT, but, the steps should be the same:
1. Solve 1.1 Monitor 1.1.1 increase "Defined Commands" to 1 1.1.2 under "ON", click to put a check 1.1.3 type in macro-1 under Command 1.1.4 click "Define macro" 1.2 Do the plotting, 1.3 Slect "File" 1.3.1 Select "Hard Copy" 1.3.1.1 select tiff 1.3.1.2 select color 1.3.1.3 type in some number for Width and height under resolution. 1.3.2 click "Save" 1.4 type in filename%t.tiff 1.5 Click "End Macro" |
Animation Error in Fluent | Andrew | FLUENT | 9 | October 1, 2020 16:42 |
How create GOOD quality animation in Fluent ? | maziboss | FLUENT | 7 | November 22, 2009 05:57 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
text shortcut commands for fluent | senthil | FLUENT | 0 | November 21, 2007 13:39 |
Fluent Animation | FV | FLUENT | 0 | September 6, 2004 09:18 |
