[:::o:::] Iges ? Fluent vs StarCD
Old   April 2, 2002, 06:31
Default [:::o:::] Iges ? Fluent vs StarCD
Natacha
Hello
Did someone know where I can find some iges of subsonic aircraft in order to make a real comparaison between Fluent and StarCD (with the same hardware)?
Natacha
Old   April 2, 2002, 11:20
Default Re: [:::o:::] Iges ? Fluent vs StarCD
FRED_PSU
Hi Natacha,
One interesting case (where lots of Cp, lift and drag data are available) is called the ROBIN (ROtor Body INteraction). It looks like a very streamlined helicopter geometry, and is defined analytically. Its shape is defined analytically, so that you can create the IGES file or directly the mesh from scratch. The original reference where it is defined is: Freeman, C. E., Mineck, R. E., "Fuselage Surface Pressure Measurements of a Helicopter Wind-Tunnel Model with a 3.15-Meter Diameter Single Rotor", NASA TM-80051, 1979.
This is a very good test case and is readily available.
Bonne chance.
Fred.
Old   April 2, 2002, 12:40
sylvain
Take a look at this site :
http://geolab.larc.nasa.gov/GridTool/ClassExamples/
Sylvain
Old   April 2, 2002, 17:45
Astrid
Natacha,
Please read the following thread, with a link to the IGESS-file.
http://www.cfd-online.com/Forum/cfx.cgi?read=2119
Astrid
Old   April 3, 2002, 04:37
Natacha
Thanks a lot, fred, sylvain and Astrid.
But i can't access to aiaa web, i don't know why.
Natacha
Old   April 3, 2002, 05:33
Jonas Larsson
The entire aiaa.org site seems to be down for the moment. It should be up again once they wake up on the other side of the atlantic.
The AIAA Drag Prediction Workshop is very interesting. You can find a link to it and several other good validation cases in the Resources/Refs section here:
http://www.cfd-online.com/Resources/refs.html#data
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 14:43
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
Comparison among CFX, STARCD, FLUENT, etc ? Jihwan Main CFD Forum 13 October 12, 2004 13:02
IGES File for practice Fluent Christian Main CFD Forum 0 August 18, 2004 10:53
Fluent or StarCD for Internal flow FVS Main CFD Forum 1 May 17, 2004 03:28
