April 7, 2002, 06:26 |
Node-Based and Cell-Centred Patterns
What deficiency and advantage have node-based and cell-centred patterns for control-volume discretisation of transport equation on unstructured grids ?
April 8, 2002, 14:19 |
Re: Node-Based and Cell-Centred Patterns
Well, for the same tetrahedral mesh for example, you get to compute the solution at 5 times more points using cell-centered calculations compared to vertex centered methods: more CPU time, more accuracy, more memory requirements,... it depends on what price you want to pay for your runs. With a cell-centered formulation, the control volume is straightforward: the cell volume and faces. Otherwise, you have to define faces that separate nodes, etc... I think CFX5 is node centered for instance...
Fred. |
Display Modes | |
[ANSYS Meshing] need to convert a cell based geometry into STL or CGNS | kamran_kibria | ANSYS Meshing & Geometry | 0 | September 15, 2011 05:14 |
Diff b/w node based & cell based methd | Murthy | FLUENT | 0 | April 2, 2008 13:18 |
which is better? vertex based or cell centered? | neil | Main CFD Forum | 1 | April 23, 2007 16:54 |
node based or cell centered Ts values | acboge | FLUENT | 0 | February 6, 2004 06:41 |
Cell Vertex Based FVM | A. S. | Main CFD Forum | 1 | January 28, 2002 07:46 |
