May 2, 2002, 08:55 |
Which Turbulence model to be used?
Hello!
Would anybody summarize me, which turbulence model to use in several problems? In case of the high Reynolds-number flows the k-epsilon or k-omega model is suitable? Gratitude: LEGO |
May 3, 2002, 08:24 |
Re: Which Turbulence model to be used?
It would be helpful if you outline the cases you wish to simulate. In general I believe the most accurate RANS turbulence models for a wide range of flows are the V2F developed by Prof. P. Durbin (Stanford) and the Wilcox K-Omega model. (+ I beleive there have been a few advance proposed on this model lately). If you are using a commercial CFD package you will probably be limited the one of the turb models in the code (unless you wish to implement one yourself?). |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 09:02 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
Fan heater model: what turbulence source to use? | andy20 | CFX | 7 | March 3, 2008 16:42 |
SSG Reynolds Turbulence Model | Georges | CFX | 1 | February 28, 2007 16:15 |
