Need experimental results on turbulent flow
Old   May 10, 2002, 13:41
Default Need experimental results on turbulent flow
babyface
I am trying to look for some experimental results on turbulent flow over sudden expansion (just like flow over BACKWARD FACING STEP ) to compare with my simulation results. Does any of you know of any papers or journals that has such experimental data? Thank you in advance.
wei rong
Old   May 22, 2002, 12:52
Default Re: Need experimental results on turbulent flow
Ajay S. Parihar
Dear Babyface, You can check ERCOFTEC data base for the experimental results in turbulent flows. Lyn and Rodi have conducted these workshop for the turbulent flows over a bluff body.
simpleFoam turbulent flow laminar results NicolasB OpenFOAM Running, Solving & CFD 22 March 25, 2016 12:31
Flow over 2D Cylinder, Laminar and Turbulent Tsr63 FLUENT 5 November 13, 2014 12:13
Turbulent flow + VOF CK FLOW-3D 3 January 13, 2009 07:30
modelling laminar and turbulent flow in the same Ol FLUENT 2 November 25, 2005 02:52
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
