May 24, 2002, 07:30 |
cavitation
Hi there,
how can i find out easily if a flow through a jet or something similar cause erosion because of bubble impact in near wall regions or not. for example: -incompressible fluid -steady state -k-eps modell -axissymm pipe-jet-pipe flow results: because of high velocities in the smallest Area there are regions downstream of the smallest gap where the static pressure is below the vapour pressure of the fluid and cavitation could exists. questions: -> how can i find out if the bubbles produced in the low pressure region will impact in the near wall regions -> what are the criterias for erosion caused by cavition -> are there simply equations to determine the critical time necessary for a impact in near wall regions, or equations for the time which a bubble needs to growth to a critical radius -> is there a method to predict a erosion caused by cavitation regards Matthias |
May 24, 2002, 09:22 |
Re: cavitation
You might run your calculation using a cavitation modell. These models are far away from beeing good but ...
May 24, 2002, 09:24 |
Re: cavitation
i know, but i have not the possibility to use a cavitation model. Is there no other way to predict erosion.
May 24, 2002, 09:55 |
Re: cavitation
Matthias,
Our CFD-ACE+ has a robust, validated cavitation model that can predict bubble formation and collapse. It would allow you to see if there is bubble collapse in the vicinity of walls. You would then have the ability to use the simulation results to make some educated guesses about the potential for erosion. "Prediction" of erosion is tricky because of the factors involved (including things like material type, surface treatment, and others). We have some plans to add an erosion prediction model to CFD-ACE+, but (like many other things) it's a matter of getting around to it. Regards, Alton |
May 24, 2002, 10:02 |
Re: cavitation
Dear Alton,
is there no other way (without a cavitation model and analytical -> something easy) to guess where the bubbles will implode and where the imploding bubbles cause erosion. best regards Matthias |
Cavitation Problems | Chris | Siemens | 4 | July 17, 2005 16:47 |
Cavitation inception problem | newuser | FLUENT | 3 | May 13, 2003 11:14 |
Cavitation Simulation by CFD | Liu, L. | CFX | 2 | November 29, 2000 13:50 |
Cavitation Simulation by CFD | Liu, L. | Siemens | 2 | November 1, 2000 21:51 |
Cavitation Simulation by CFD | Liu, L. | Main CFD Forum | 7 | November 1, 2000 21:26 |
