Conjugate Heat Transfer- HELP!
Old   June 26, 2002, 07:45
Default Conjugate Heat Transfer- HELP!
H. Roy
Can you please suggest how to solve congugate heat transfer problems using PHOENICS.
Shall be greatful for hints/ ellaborate suggetsions
Old   June 27, 2002, 01:06
Default Re: Conjugate Heat Transfer- HELP!
Paul
To solve conjugate heat transfer problems with PHOENICS, the whole domain - including the solid wall and the fluid - is solved together. The basic idea is to set the viscosity in the solid part to a large one, say 10^20. Special care shoule be given to ensure the continuity of the heat flux across the solid-fluid interface. There are some demo cases in the PHOENICS, you may find some similar to yours. I solved such problem four ago and forgot the details. Sorry for this and good luck.
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 17:31
Conjugate heat transfer and radiation modeling questions shankara.2 FLUENT 0 April 21, 2009 15:55
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
