Which software can model more than two phase fluid |
August 27, 2002, 11:55 |
Hi, everyone,
I want to model the slurry with at least three size of particles distributing in it. I want to know the separation process of the slurry under gravity sedimentation. Anyone know which software has such capability? Thank you! J.Yang |
August 27, 2002, 14:17 |
Re: Which software can model more than two phase f
CFX can do this kind of simulations. Best regards |
August 27, 2002, 14:25 |
I think most software with an euler euler solver for multiphase flow should be able to do that. If I understand it correctly then it is just a matter of solving an additional similar equation for each size group. I standard answer to such a question in this forum is try to contact the different software vendors and ask them your question - look under the resources pages. Good luck
August 27, 2002, 22:02 |
But CFX only can model two phase fluid
Hi, thank Alian and Jan for your helping. But CFX only can model two phase fluid. My problem is that I want to model the slurry with various sizes of dispersed solid particles distributing in continuous water. The solid particle size ranges from 0.2 micron to 2 mm. So I need model every particle group using one phase.
Thank you very much! J.Yang |
August 28, 2002, 03:21 |
Re: But CFX only can model two phase fluid
You still only have two phases - slurry and the particles! The number of size groups has nothing to do with a phase - they are still "a particle phase" You can then solve more equations for your dispersed phase representing each size group. Jan
August 28, 2002, 03:24 |
IMO You should look for a program which solve the transport equations for particle/droplet groups (probably in a Lagrangian way). The particle size range is subdivided into appropriate classes and a transport equation for each particle group is solved.
I think using a multiphase approach is not appropriate for your problem and computational not feasible. If you have a lot of different particle size classes they should not be modelled as a continuum. |
August 28, 2002, 04:58 |
Dear Free_and SIMPLE I could be wrong on this, but then hopefully will be corrected.
The selection of how to model a system with a fluid and particles depends mainly on the load, how dense or diluted the dispersed phase is. For very high mass loading is the euler/euler prefered. The main problem with euler/euler and multiple size groups is that a transport equation has to be solved for each size group - so it depends on your hardware. But 3 or 4 size groups should not be a problem, that is at least what I have solved on my small PC. Maybe there also exist euler/euler codes that can handle a size distribution. Jan |
August 29, 2002, 02:28 |
Dear Jan,
of course you are correct. The model of choice depends on the load. The problem I see with Euler/Euler continuum treatments is the physical sound formulation. If you treat the size groups as scalar quantities with global interactions it will work, but if you are looking for a "real" multiphase model, where each group has its own velocity field you might run into troubles. An alternative can be a pdf approach which is very common in combustion and spray simulation. Best Regards. |
September 3, 2002, 06:37 |
#9 |
As a matter of fact CFX has the capability of solving EULER/EULER multiphase with more than 2 phase : In CFX 5 (unstructured) you can use pure euler/euler with up to 5 phase but there is no granular euler which you may need. In CFX 4 (structured) an arbitrary number of phases may be specified. There is also a specific model MUSIG (Multiple-Size Group) which is available to represent the size distribution of a disperse phase. There is certainly other software that can do this kind of simulation i think. From theorical point of view I don't think that euler lagrange approach is suitable for sedimentation problem as this model suppose a finite residence time for particules. Best regards Alain |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
Two phase model? | pathway | FLUENT | 0 | September 15, 2009 23:41 |
phase change of a dispersed fluid | Alex phillips | CFX | 1 | October 23, 2006 14:40 |
questions about the discrete phase model | lisa | FLUENT | 3 | January 17, 2006 07:51 |
