Non-dimensional k-w
Old   September 14, 2002, 18:43
Default Non-dimensional k-w
CH
Hi all. I am trying to implement Wilcox's two equation k-w turbulence model, and am having a hard time with the non-dimensionalization of 'w'. What is the appropriate non-d parameter:
(1) w_inf = U_inf/L-inf
(2) w_inf = (U_inf)**2/L-inf
(3) w_inf = sqrt(U_inf**3 /(Nu_inf * L-inf))
Depending on the parameter used, the Reynolds number term appears in front of the Dissipation term. What is the physics behind determining which parameter to use? Is it a problem-based choice? My test cases would involve supersonic external flows.
Thanks for all your input.
Old   September 14, 2002, 18:46
Default Correction
CH
Oops! The second parameter should have been
(2) w_inf = U_inf/Nu_inf
which gives the correct dimensions of 1/time for w.
Thanks!
Old   September 16, 2002, 09:36
Default Re: Non-dimensional k-w
sylvain
If you already have a k-eps model implemented, look at its non-d parameters. First of all, w=eps/k, so the non-dimensionalized form of k and eps will give you the appropriate form of w.
Sylvain
two dimensional supersonic ramjet inlet model Alex FLUENT 1 November 17, 2017 11:45
Two or Three Dimensional for a coil Asghari_M ANSYS Meshing & Geometry 0 June 7, 2011 05:28
importing geometry from three dimensional subject George Kagadis FLUENT 0 September 30, 2004 01:35
Non- Dimensional Analysis Bikash FLUENT 0 September 1, 2004 02:35
Non Dimensional Parameters J.J Main CFD Forum 1 June 28, 2000 20:12
