February 4, 1999, 04:30 |
mapping with Thompson scheme
I am a beginner of CFD. I tried to use thospson scheme to map uniformly spaced circles in physical space into a uniform rectangular grid in the computational plane. I specified boundary conditions with polor coordinate r=0~1, then transfer into cartesian coordinate x and y. But if the domain is 0~pi/2, the results of x and y are correct, uniformly spaced circles can be achieved. If the domain is 0~2pi, the results will be changed, the space of radial direction is not expected. Would anybody give any suggestion about it? Thanks in advance! Juliet |
February 6, 1999, 00:58 |
Re: mapping with Thompson scheme
Hi Juliet, There is an easier way than the Thompson scheme. This way is called mathematical grid generation, where you map your grid using some described mathematical function.
As for your problem, you may didn't use the appropriate periodic boundary condition. If you have any question just feel free to ask me through thisa email Eiyad |
Display Modes | |
how to understand high resolution scheme and high order scheme | iilw1314 | Main CFD Forum | 7 | April 12, 2022 13:29 |
2nd order upwind scheme (Fluent and CFX) | Far | FLUENT | 0 | May 22, 2011 02:50 |
extrapolation in MUSCL scheme | Chandra | Main CFD Forum | 6 | February 14, 2007 12:21 |
pave mapping scheme | julie | FLUENT | 0 | November 2, 2005 10:33 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
